Настройка Apexi Boost Kit к Apexi Power FC |
7.5.2007, 13:56
Пользователь ![]() ![]() Группа: Пользователи Сообщений: 97 Регистрация: 27.3.2007 Пользователь №: 1136 |
А стоковые турбы разве столько выдавят?
7.5.2007, 12:57
Во Диму Иппония тОркнула
в баню 1,7! Дима, давай 2,0 |
7.5.2007, 10:17
7.5.2007, 9:49
блин ну я тупой.... вопрос снимается. Я ЗАБЫЛ ЕГО ВКЛЮЧИТЬ В НАСТРОЙКАХ ETC !!!!
How do I configure the Optional Boost Controller Kit? Once the harness and sensors have been connected you need to turn the Boost Controller Kit on under ETC, FUNCTION SELECT. You need to set the Boost Kit option to ON. The OFF Symbol looks like a plus sign in Japanese so be sure its opposite to this. All that is left is to the set the disired boost pressure, SETTING and then BOOST. On this screen you will be presented with 4 options. Each option is a preset boost pressure and duty item, the currently selected one is the active "boost profile". The first value is Boost Profile Number. The second value is the maxmium amount of boost you wish to run. The third value is duty cycle The fourth value is unused (always 255). Boost Pressure 1. 1.00 kg/cm2 40 255 2. 1.10 kg/cm2 46 255 3. 1.20 kg/cm2 52 255 4. 1.30 kg/cm2 60 255 Choose boost profile #1 Set target boost pressure Do a test 3rd gear drive and see what boost it reaches Adjust duty cycle as needed Lower number if boost is too high over target boost or if safety cut is reached. Increase number if boost is too low or it doesn't reach desired level. If the map sensors detects that boost pressure is 0.25kg/cm2 over the set boost pressure then it will do a safety cut to protect itself. If you find the car is unable to make the pressure you desire, increase the duty cycle value. If you find it makes it to easily or it's having trouble maintaing a stable pressure or keeps hitting the cut limit then turn the duty value down. You can also set the other 3 boost profiles here if you wish so that you can select these later on allowing you to quickly change preset boost on the fly. The current selected profile (option 1,2,3 or 4) is active when you it's highlighted and you press PREV to navigate to the other menu's. |
7.5.2007, 9:36
Значится прикручен кит к рыксе... Вопрос к знатокам... Как его настроить чтобы пожгла неподеццки ?
Сейчас симптомы такие...Берем ровный разгон на 2 передаче. После включения первой турбины по дефям вижу начинает давить 1, идет хороший набор, НО в момент включения 2-й турбины, это около 4.5-5 тыс об, идет провал, так как буст падает до 0.6... И потом на таком бусте идет до отсечки оборотов... Хороший набор кончается туплением.... Вид экрана настроек буст, примерно такое - 1. Pr 0.8 kg 62% Sc 0.7 kg 70% 2. Pr 0.9 kg 58% Sc 0.8 kg 64% вопрос... что значит 1, 2 .... что дают изменения Килограмм, что дают изменения %% ??? Как сделать чтобы поехала ? |
Текстовая версия | Сейчас: 29.8.2026, 9:17 |
